I’m desperate find a tip to change legend of my veeam pannel : Status History
Query :
veeam_job_result{job=“veeam_report”}>-2
I don’t want the value of metrics of the query, in the legend like : 0 , 1 , -1
I want : 0 = Backup ok ; -1 = running , -2 = Error
I try “Value mappings” , with exact or regex , It change the tooltips when I move the mouse on a square, but not the legend.
Last version, : 9.4 2023 , with prometheus last version (source) and pushgateway and powershell script send value. -
change Legend value on pannel “Status history”
- How are you trying to achieve it?
mapping value
I want : 0 - Backup ok ; -1 running , -2 = Error ----> at the legend
After searching through all the options, I thought I would change the value of the result,
for example change ; 0 by backupok , 1 by running etc… for that I change the powershell script, but invoque-webrequest refuse send data to pushgateway because Its not Float …
I discovered that “metrics” means numbers ! it’s not easy to send something else than numbers as values for metrics.(string)
Thanks for helping.
