Hi all,
Grafana v8.4.5 (4cafe613e1) -
I would like to change the Legend of an Query (displaying currencies of an game) depending on label
{{id}}(that from the query) with a static list / map / json / … but I did not find a solution.My panel looks like this at the moment:
The real description / text of currencies are not in the prometheus-metrics - only the id’s are in the data. I don’t want to store the name in the prometheus-data because that are static data. The text of the currencies are in an static json that I would like store in grafana itself. It’s should look like:
{ "1" : "Coin", "2" : "Karma", "14": "Gem", "15": "xxxx", "19": "yyyyy", ... } -
What happened?
The Data from the variables are not mixed with the
{{id}}from the query. -
I have tried different approches with variables (custom, query and constant) but I didn’t get the result that I would like to have.
[{"__value":"1","__text":"Coin"},{"__value":"2","__text":"Karma"}]1 : Coin,2 : Karma{"1" : "Coin","2" : "Karma"}
And tried to use this in the Legend field of the query like:
$currencies{{id}}$currencies.{{id}}$currencies\.{{id}}- and something other that I found n the web
but I didn’t found anything that work’s
Here a small picture what I would like to to achieve - I have manipulated the data via Browser Inspector for the first rows.
I looked for many post’s and guide’s in the web:
- Variable syntax | Grafana documentation
- Add and manage variables | Grafana documentation
- and much more (I can only put 2 links in the post as a new user) …
Can someone help me with this topic or is this not intended to do this with grafana?
Thank
Zero
