Issue Rendering Legends
    I am trying to display legends as “graph”, “businesslogic”, “fetch” etc.
    I have a DB Table with below values
Below is the query
select
queue_name from QueueMonitor
where queue_name IN (‘graph’, ‘triggers’, ‘publiclink’, ‘publisher’, ‘businesslogic’, ‘renditions’, ‘fetch’, ‘actions’)
AND $__timeFilter(timestamp)
  • What happened?
    I am only viewing “value” as one of the legend or my be not.
    I was expecting to have “graph”, “businesslogic”, “fetch” etc. as legend
    There are no error
    Create a dashboard | Grafana documentation
Add variables | Grafana documentation
Hello cellyamit , i understand your problem and facing same issues using disply name , i try to solve your problem using grafana variable and then use transformation to achive your requirement.
follow the step to solve this issues
Step 1 : Add variable and configure it.
Step 2: Write query to fetch data from db table
Step 3: Add these transformation
Final output
Dear @infofcc3
Thank you so much for your prompt reply and I highly appreciate your support.
Based on the suggestion I am to view the expected result
Though results are as expected however, I am wondering, I am able to view the dots-flow, but what is it that is restricting to display line chart.
Could you please share your insights?
Best Regards,
cellyamit
Hello @infofcc3
I was able to get lines displayed, refer the below screengrab
Further, I just observed a scenario that on refresh, graph flickers due to number of selected value in variable i.e. $fetchQueue, is there a possibility to hide variable list and let it be dynamically get displays as legend, so to avoid the flickering.
Let me know if this makes sense.
Looking forward for your support.
Best Regards,
cellyamit
My Apologies. but I was able to hide the variable.
This should be my last comment, but once again, I would like to extend my gratitude for you in providing your expert advice and suggestion.
Many thanks!!
Best Regards,
cellyamit
Thanks for your feedback @cellyamit
