Legend appears twice ... when I have data sources on one graph?
I am very new to Grafana, I have created a chart with one data source and the legend is shown correctly.
I then created another chart with 2 data sources and now the legend shows … Electric Electric … it should only show Electric once. It may be my query is wrong or is there something in Grafana I need to change ?
OR it maybe I use 2 separate queries for the graph, like this …
select json_extract( value, ‘$.Gas_reading’ ) as Gas, json_extract( value, ‘$.iso’) as time from DATABASE, json_tree( DATABASE.data, ‘$.IP15’ ) where type = ‘object’ and json_extract( value, ‘$.Gas_reading’ );
select json_extract( value, ‘$.Electricity_reading’ ) as Electicity, json_extract( value, ‘$.iso’) as time from DATABASE, json_tree( DATABASE.data, ‘$.IP22’ ) where type = ‘object’ and json_extract( value, ‘$.Electricity_reading’ );
Ithink they should be one query, but how ?
Thanks Gaz
Try to Change it from Tables to Time Series
It is already set to Time series.
I am using a JSON SQlite databse and I do not seem to have your choices of queries shown above or do i need to add or change something ?
thanks Gaz
Where is it set as such? Let me try to spin up a sqllite db locally and test it
Which SQLLite plugin are you using?
Maybe you can use transform tab to change it into a time series ?
Hi yosiasz
I am using
07
while I get that spun up, what happens if you removed the alias
as Electricity
also what version of grafana are you on?
10
grafana 9.0.7
If this helps …
My Database setup
03
and the objects that are in the above Database DATA table.
you want me to retype all of that :stuck_out_tongue_winking_eye:
Please post as text and not as an image?
ha ha yes i did think of that just now … here you are
“IP15”: [
“Gas_reading”: 0,
“iso”: “2022-08-19T14:40:55.069Z”,
“location”: “Garage”,
“timestamp”: 1660920055
and the other
“IP22”: [
“Electricity_reading”: 2.787,
“iso”: “2022-08-19T14:41:31.765Z”,
“timestamp”: 1660920092
Hi again,
I have just found this … follow the link
The reply is from the man that wrote the addon.
I cannot find the … Grafana visualization configuration.
Where would that be ?
Thanks Gaz
sorry got stuck in python trying to import your data :frowning:
Hi yosiasz,
Thanks for your help I finally found out what the problem was you have to change …
then you get
13
Easy when you find the answer :disappointed_relieved:
anyway thanks for your help and have a great day
Gaz
that sounds hard to maintain if a new reading type comes in. this should be done dynamically
using Merge I get the following
without merge (double vision) :eyes:
and it makes sense cause without merge you have 2 frames of data. So it is being helpful to differentiate one from the other.
Also I would go for 1 query approach with maybe a pivot.
You shouldn’t have to add an “override” but just use the regular “display name” setting.
This works pretty well in my opinion.
Version 3.1.1 of the plugin will have a bit better naming here but the core issue of more information added to the legend is due to Grafana (especially if using multiple lines in a chart).
Some more information can also be found here: Legend appears twice · Issue #96 · fr-ser/grafana-sqlite-datasource · GitHub
