LDAP Configuration : Support
Hi Team,
Need help !
I’m new to grafana . Now i’m in progression of configuring LDAP setup in our environment.
Not sure how and where to start in our Dev Instance. We have 1 App server (Grafana) & 1 DB server(Influxdb) . Grafana recommendations to use Open LDAP for LDAP configuration.
Give me some tips to complete the end to end LDAP set up in Grafana?
Regards,
Angel17
How much of https://grafana.com/docs/auth/ldap/ have you done so far and where
did you run into problems?
Antony.
Hi Pooh…
Thanks for your reply!!
I have not done any setup earlier. I’m new to this tool. We are using open source. on going thru the link . Have few questions
So which LDAP server is recommended
I can see OpenLDAP already installed in our Dev Instance
How to make use of OpenLDAP and try to test the LDAP Setup
Can i give the sample example for configuring .ini files to activiate LDAP?
Also give suggestions on SSL & Hostname change(from ipaddress to app name)
Regards,
Angel17
Regards,
Ramya
Hi Pooh…
Well, it is generally polite to have done a bit of research and tried to solve
problems yourself before asking for assistance on a mailing list or forum…
And incidentally, I have never used LDAP with Grafana, so beyond pointing you
at some documentation which people have already put the effort into writing, I
am no expert on this topic.
I don’t know that the Grafana team “recommend” any particular LDAP server;
they support compatibility with several which you can choose from.
In that case use OpenLDAP.
That’s not a Grafana question, and is totally outside my areas of expertise.
I recommend you look up some OpenLDAP guides or ask on an OpenLDAP list for
this type of assistance.
I’m not at all sure what you’re referring to there. I think the link I
pointed you at contains samples of all the configuration files you need.
That’s a totally different question, but I think
may help you there. If not, I suggest you create a new thread to address this
different topic.
Regards,
Antony.
