LDAP Autentication -Grafana
Hi guys can you advice me to deploy this configuration ?
I will use the email to acess the aplication i am not sure about the correct configurarion.
ldap.toml
To troubleshoot and get more log info enable ldap debug logging in grafana.ini
[log]
filters = ldap:debug
[[servers]]
Ldap server host (specify multiple hosts space separated)
host = “employ.dev.com
Default port is 389 or 636 if use_ssl = true
port = 389
Set to true if ldap server supports TLS
use_ssl = false
Set to true if connect ldap server with STARTTLS pattern (create connection in insecure, then upgrade to secure connection with TLS)
start_tls = false
set to true if you want to skip ssl cert validation
ssl_skip_verify = false
set to the path to your root CA certificate or leave unset to use system defau lts
root_ca_cert = “/path/to/certificate.crt”
Authentication against LDAP servers requiring client certificates
client_cert = “/path/to/client.crt”
client_key = “/path/to/client.key”
Search user bind dn
bind_dn = “ou=employ.dev,o=employ.dev”
Search user bind password
If the password contains # or ; you have to wrap it with triple quotes. Ex “”" #password;"""
bind_password = ‘grafana’
User search filter, for example “(cn=%s)” or “(sAMAccountName=%s)” or “(uid=%s )”
search_filter = “(cn=%s)”
An array of base dns to search through
search_base_dns = [“ou=employ.dev,o=employ.dev”]
For Posix or LDAP setups that does not support member_of attribute you can de fine the below settings
Please check grafana LDAP docs for examples
group_search_filter = “(&(objectClass=posixGroup)(memberUid=%s))”
group_search_base_dns = [“ou=employ.dev,o=employ.dev”]
group_search_filter_user_attribute = “mail”
Specify names of the ldap attributes your ldap uses
[servers.attributes]
name = “givenName”
surname = “sn”
username = “cn”
member_of = “memberOf”
email = “mail”
Map ldap groups to grafana org roles
[[servers.group_mappings]]
group_dn = “ou=employ.dev,o=employ.dev”
org_role = “Admin”
To make user an instance admin (Grafana Admin) uncomment line below
grafana_admin = true
The Grafana organization database id, optional, if left out the default org (i d 1) will be used
org_id = 1
group_dn = “cn=users,dc=grafana,dc=org”
org_role = “Editor”
If you want to match all (or no ldap groups) then you can use wildcard
group_dn = “*”
org_role = “Viewer”
I am seeing the ldap server in my browser but when i am testing i am geting
No user was found in the LDAP server(s) with that username
Hello, did you ever get this completed? I’m looking at the same issue and was wondering if you could share what you’ve done to get it working.
Thanks
I got also problems with starting up ldap, solved them (at least login is possible now)
The good thing is you have already contact with the server.
Did you switch debugging on?
The log messages shall be helpful.
The ldapsearch tool helped me a lot, I am working under windows.
See also:
