Lables not being attached to Log Data
Hi all,
I’m trying to attach some labels to my log data from Promtail for Loki. These logs are coming from my FortiGate Firewall and are outputted like this:
Nov 14 03:34:32 172.20.200.1 date=2023-11-14 time=03:34:32 devname="600F-Primary" devid="redacted" eventtime=1699896872275088216 tz="+1000" logid="0000000013" type="traffic" subtype="forward" level="notice" vd="root" srcip=10.10.3.1 srcport=52200 srcintf="port3" srcintfrole="undefined" dstip=23.202.164.20 dstport=443 dstintf="port2" dstintfrole="wan" srccountry="Reserved" dstcountry="Australia" sessionid=336143154 proto=6 action="server-rst" policyid=36 policytype="policy" poluuid="42405eae-e786-51ec-eb3e-c8e961df790a" policyname="Restrictions" user="redacted" group="Restrictions" authserver="FSSO Server" service="HTTPS" trandisp="snat" transip=110.145.195.106 transport=52200 appid=38900 app="Apple.Store" appcat="General.Interest" apprisk="elevated" applist="Restrictions" appact="detected" duration=5 sentbyte=1255 rcvdbyte=12658 sentpkt=17 rcvdpkt=15 shapingpolicyid=16 shaperperipname="Apple IP Shaper" shaperperipdropbyte=0 vwlid=0 wanin=7619 wanout=387 lanin=840 lanout=840 utmaction="block" countweb=1
I am trying to label logs based upon the value defined within the type=“traffic” or type=“utm” to better filter and reduce log query time.
Here is my Promtail Configuration file:
  - job_name: fortigate
    static_configs:
      - targets:
          - localhost
        labels:
          job: "fortigate"
          __path__: /var/log/fortigate/fortigate.log
    relabel_configs:
      - source_labels: ['__raw_log__']
        regex: '.*type=(traffic|utm).*'
        target_label: 'log_type'
        replacement: '$1'
I have attempted to use a Regex Validator online and tried with and without the ’ at the end, the . at the end and the * at the end, but to no avail.
I should see these logs with labels, although all my logs come in as (no unique labels).
What steps should I take to troubleshoot, I’ve asked ChatGPT and still nothing. The systemctl and journalctl logs aren’t indicating anything and the instance reboots correctly.
Any help is appreciated.
You need two steps, first step to do a regex group capture, second step to assigned captured value into a label. Something like this (not tested):
pipeline_stages:
  - regex:
      expression: '^.+\stype=\"(?P<log_type>.[^\"]+)\"'
  - labels:
      log_type:
Hi Tonyswumac,
You are so right!
I eventually tried out a different method, which mimics the label tag after the definitions/expression.
If anyone else stumbles across this, this is what I did:
  static_configs:
    - targets:
        - localhost
      labels:
        job: "fortigate"
  pipeline_stages:
    - logfmt:
        mapping:
          type:
          subtype:
          policyid:
    - labels:
        type:
        subtype:
        policyid:
