Knative dashboard
how can I get knative dashboard , I am not able to find anywhere
I see someone has used in below link , but not sure how to access ?
I am looking both of this dashboard
Knative Serving- scaling and
Revision HTTP Requests
Did you try to import this :
Good Luck
do not think, above code is working code
When I try to import the above one it throws an error
You’ll have to go through and remove the lines of yaml that are there for Openshift/Kubernetes deployment.
