We are using grafana 7 version deployment on kubernetes. -
Am trying to get kubernetes deployment images information onto grafana dashboard, also would like to export the output of the kubectl commands to grafana dashboard to monitor additional metrics. -
Am just trying to understand if there is any was this can be done, if there is any existing functionality in grafana which can help with task -
What happened?
