- 12.1.1
- Display dashboard “kiosk mode” without menu bar or time picker
- Chromium browser opened via script to the URL of the dashboard on raspberry pi OS running on raspberry pi hardware
What happened?
- Some of the dashboards show the menu bar. Sometimes the menu bar re-appears and disappears. That’s probably also because they are set to auto refresh every 1 hour.
- I expect the menu bar to never appear.
- chromium-browser --noerrdialogs --kiosk --incognito hostname/d/smONTJ1Mz/routers-and-network-overview?orgId=1&from=now-12h&to=now&refresh=5m&kiosk
- None that I recall seeing
