Disable top bar in kiosk mode
Since the last update, when I’m in kiosk mode, the bar at the top is no longer hidden. Is it possible to hide it?
Thank you
try adding &kiosk to the end of your grafana url, or &kiosk=tv depending what you want to hide
It doesn’t seem to work. My url:
https://monitoring.xxx.net/d/0QuE7IfWz/dashboard?orgId=1&refresh=1m&var-
exporter_node=$__all&var-nginx_node=$__all&var-exporter_node_s=$__all&var-exporter_node_m=$__all&kiosk&from=now-30m&to=now-1m
I tried : https://monitoring.xxx.net/d/0QuE7IfWz/dashboard?orgId=1&refresh=1m&var-
exporter_node=$__all&var-nginx_node=$__all&var-exporter_node_s=$__all&var-exporter_node_m=$__all&kiosk=tv&from=now-30m&to=now-1m
I just want to hide the red bar in the screenshot.
try removing the links, and hiding the time picker:
Is it possible to tell me where I need to go to configure this?
But I don’t think this is the solution since before the update the whole bar was hidden by default in kiosk mode
any news?
