When running my k6 test locally, it outputs information about all the scenarios that ran. However, running inside k8s cluster with the k6-operator, the log from the test pod does not include any information about the scenarios ran.
From pod log:
█ setup
█ teardown
data_received..................: 17 kB 185 B/s
data_sent......................: 7.6 kB 85 B/s
http_req_blocked...............: avg=39.52µs min=3.45µs med=4.22µs max=1.01ms p(90)=17.52µs p(95)=18.64µs
http_req_connecting............: avg=6.45µs min=0s med=0s max=193.6µs p(90)=0s p(95)=0s
http_req_duration..............: avg=10.67ms min=9.59ms med=10.46ms max=14.57ms p(90)=11.35ms p(95)=12.5ms
{ expected_response:true }...: avg=10.67ms min=9.59ms med=10.46ms max=14.57ms p(90)=11.35ms p(95)=12.5ms
http_req_failed................: 0.00% ✓ 0 ✗ 30
http_req_receiving.............: avg=61.2µs min=48.92µs med=58.07µs max=118.68µs p(90)=71.88µs p(95)=77.22µs
http_req_sending...............: avg=18.92µs min=14.1µs med=17.12µs max=50.55µs p(90)=22.07µs p(95)=22.84µs
http_req_tls_handshaking.......: avg=0s min=0s med=0s max=0s p(90)=0s p(95)=0s
http_req_waiting...............: avg=10.59ms min=9.53ms med=10.38ms max=14.48ms p(90)=11.28ms p(95)=12.4ms
http_reqs......................: 30 0.33332/s
iteration_duration.............: avg=10.17ms min=8.46µs med=10.55ms max=14.69ms p(90)=11.41ms p(95)=12.98ms
iterations.....................: 30 0.33332/s
vus............................: 0 min=0 max=0
vus_max........................: 1 min=1 max=1
From local run otput:
scenarios: (100.00%) 1 scenario, 1 max VUs, 35s max duration (incl. graceful stop):
* TEST_SCENARIO: 1.00 iterations/s for 5s (maxVUs: 1, exec: doTest, gracefulStop: 30s)
█ setup
█ teardown
data_received..................: 4.0 kB 792 B/s
data_sent......................: 1.3 kB 264 B/s
http_req_blocked...............: avg=28.32µs min=3.62µs med=4.57µs max=148.13µs p(90)=76.44µs p(95)=112.28µs
http_req_connecting............: avg=15.73µs min=0s med=0s max=94.42µs p(90)=47.21µs p(95)=70.81µs
http_req_duration..............: avg=162.05ms min=18.47ms med=50.29ms max=773.67ms p(90)=416.51ms p(95)=595.09ms
{ expected_response:true }...: avg=162.05ms min=18.47ms med=50.29ms max=773.67ms p(90)=416.51ms p(95)=595.09ms
http_req_failed................: 0.00% ✓ 0 ✗ 6
http_req_receiving.............: avg=70.81µs min=57.24µs med=72.14µs max=84.98µs p(90)=79.46µs p(95)=82.22µs
http_req_sending...............: avg=21.43µs min=15.33µs med=17.59µs max=31.08µs p(90)=30.92µs p(95)=31µs
http_req_waiting...............: avg=161.96ms min=18.4ms med=50.2ms max=773.56ms p(90)=416.41ms p(95)=594.98ms
http_reqs......................: 6 1.195033/s
iteration_duration.............: avg=121.67ms min=8.38µs med=35.38ms max=773.98ms p(90)=273.86ms p(95)=523.92ms
iterations.....................: 6 1.195033/s
running (05.0s), 0/1 VUs, 6 complete and 0 interrupted iterations
TEST_SCENARIO ✓ [======================================] 0/1 VUs 5s 1.00 iters/s
Am I missing some configuration?
