Hi all,
I am trying to pass journal logs via Promtail on server A to Loki on server B. Now it seems none of the journal logs ever gets read by Promtail.
Promtail config
global:
file_watch_config:
min_poll_frequency: 250ms
max_poll_frequency: 250ms
server:
http_listen_network: tcp
http_listen_address: ""
http_listen_port: 9080
http_listen_conn_limit: 0
grpc_listen_network: tcp
grpc_listen_address: ""
grpc_listen_port: 0
grpc_listen_conn_limit: 0
tls_cipher_suites: ""
tls_min_version: ""
http_tls_config:
cert_file: ""
key_file: ""
client_auth_type: ""
client_ca_file: ""
grpc_tls_config:
cert_file: ""
key_file: ""
client_ca_file: ""
register_instrumentation: true
graceful_shutdown_timeout: 30s
http_server_read_timeout: 30s
http_server_write_timeout: 30s
http_server_idle_timeout: 2m0s
grpc_server_max_recv_msg_size: 4194304
grpc_server_max_send_msg_size: 4194304
grpc_server_max_concurrent_streams: 100
grpc_server_max_connection_idle: 2562047h47m16.854775807s
grpc_server_max_connection_age: 2562047h47m16.854775807s
grpc_server_max_connection_age_grace: 2562047h47m16.854775807s
grpc_server_keepalive_time: 2h0m0s
grpc_server_keepalive_timeout: 20s
grpc_server_min_time_between_pings: 5m0s
grpc_server_ping_without_stream_allowed: false
log_format: logfmt
log_level: info
log_source_ips_enabled: false
log_source_ips_header: ""
log_source_ips_regex: ""
log_request_headers: false
log_request_at_info_level_enabled: false
log_request_exclude_headers_list: ""
http_path_prefix: ""
external_url: ""
health_check_target: null
disable: false
profiling_enabled: false
enable_runtime_reload: false
client:
url: ""
batchwait: 1s
batchsize: 1048576
follow_redirects: false
enable_http2: false
backoff_config:
min_period: 500ms
max_period: 5m0s
max_retries: 10
timeout: 10s
tenant_id: ""
drop_rate_limited_batches: false
stream_lag_labels: ""
clients:
- url: http://serverb:3100/loki/api/v1/push
batchwait: 1s
batchsize: 1048576
follow_redirects: true
enable_http2: true
backoff_config:
min_period: 500ms
max_period: 5m0s
max_retries: 10
timeout: 10s
tenant_id: ""
positions:
sync_period: 10s
filename: /tmp/positions.yaml
ignore_invalid_yaml: false
scrape_configs:
- job_name: syslog
syslog:
listen_address: 0.0.0.0:10514
listen_protocol: ""
idle_timeout: 0s
label_structured_data: false
labels:
job: syslog
use_incoming_timestamp: false
use_rfc5424_message: false
max_message_length: 0
relabel_configs:
- source_labels: [__syslog_message_hostname]
separator: ;
regex: (.*)
target_label: hostname
replacement: $1
action: replace
- source_labels: [__syslog_message_severity]
separator: ;
regex: (.*)
target_label: level
replacement: $1
action: replace
- source_labels: [__syslog_message_app_name]
separator: ;
regex: (.*)
target_label: application
replacement: $1
action: replace
- source_labels: [__syslog_message_facility]
separator: ;
regex: (.*)
target_label: facility
replacement: $1
action: replace
static_configs: []
- job_name: system
static_configs:
- targets:
- localhost
labels:
__path__: /var/log/*log
__path_exclude__: /var/log/lastlog
job: varlogs
- job_name: journal
journal:
max_age: 12h
json: false
labels:
job: systemd-journal
path: /var/log/journal
matches: _TRANSPORT=kernel
relabel_configs:
- source_labels: [__journal__systemd_unit]
separator: ;
regex: (.*)
target_label: unit
replacement: $1
action: replace
static_configs: []
target_config:
sync_period: 10s
stdin: false
limits_config:
readline_rate: 1000
readline_burst: 2000
readline_rate_enabled: true
readline_rate_drop: true
max_streams: 0
max_line_size: 0B
max_line_size_truncate: false
tracing:
enabled: true
wal:
enabled: false
dir: ""
cleanSegmentsOlderThan: 0s
watchConfig:
minReadFrequency: 0s
maxReadFrequency: 0s
I created /var/log/journal by following systemd-journald.service and executing the following commands:
mkdir -p /var/log/journal
systemd-tmpfiles --create --prefix /var/log/journal
Systemd
systemctl --version
systemd 252 (252-14.el9_2.3.0.1)
+PAM +AUDIT +SELINUX -APPARMOR +IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS -FIDO2 +IDN2 -IDN -IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT -QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK +XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified
The Promtail process is running as user promtail and I explicitly verified it can read all the logs (accomplished by using file ACLs).
getfacl /var/log/
getfacl: Removing leading '/' from absolute path names
# file: var/log/
# owner: root
# group: root
user::rwx
user:promtail:r-x
group::r-x
mask::r-x
other::r-x
The logs from the jobs syslog and system do get passed to Loki. The promtail log (in journald) does not show any signs of errors.
Am I missing something in the config for it to work?
