Grafana 10.0.3 -
By default, if I graph a metric, Grafana display info on all devices. For example, the ‘io_wait’ metric, it’ll graph all disks. I really just want an overall value for all disks. Same with Network stats, it’ll show ‘err_in’ for all network interfaces.
from(bucket: “InfluxBucket”)
|> filter(fn: (r) => r[“_measurement”] == “diskio”)
|> filter(fn: (r) => r[“_field”] == “io_time”)
|> filter(fn: (r) => r[“host”] == “${host}”)
|> aggregateWindow(every: v.windowPeriod, fn: sum, createEmpty: false)
|> yield(name: “sum”) -
What happened?
result auto show ‘io_wait’ for sda, sdb, sdc, etc. -
Just one ‘io_wait’ value -
Query above -
No errors -
Multiple articles about joining transform options, none helped.
