im new to Flux and to the community so please tell me if i posted the topic in the wrong category or with the wrong tags. I couldn’t do this task using the Transform tabs so i hoped i could do this with flux
I have two data streams from a factory. The first one contains factory data e.g. temperatures or weights.
| time | field_float_value_float | tag_generic_name | tag_workorder |
| 24.2.21 4:56:50 | 13 | Weight1 | A001 |
| 24.2.21 4:58:50 | 380 | Weight1 | A002 |
| 24.2.21 5:03:50 | 14 | Weight1 | A001 |
| 24.2.21 5:05:50 | 386 | Weight1 | A002 |
| 24.2.21 5:24:50 | 14 | Weight1 | A001 |
| 24.2.21 5:26:50 | 379 | Weight1 | A002 |
| 24.2.21 5:36:50 | 15 | Weight1 | A001 |
| 24.2.21 5:38:50 | 381 | Weight1 | A002 |
| 24.2.21 5:53:50 | 13 | Weight1 | A001 |
| 24.2.21 5:54:50 | 386 | Weight1 | A002 |
| 24.2.21 5:01:50 | 359 | Weight2 | A001 |
| 24.2.21 5:04:50 | 69 | Weight2 | A002 |
| 24.2.21 5:23:50 | 358 | Weight2 | A001 |
| 24.2.21 5:26:50 | 65 | Weight2 | A002 |
| 24.2.21 5:37:50 | 359 | Weight2 | A001 |
| 24.2.21 5:40:50 | 64 | Weight2 | A002 |
| 24.2.21 5:52:50 | 359 | Weight2 | A001 |
| 24.2.21 5:55:50 | 64 | Weight2 | A002 |
| 24.2.21 6:07:50 | 360 | Weight2 | A001 |
| 24.2.21 6:10:50 | 66 | Weight2 | A002 |
The second table contains data about the order e.g. the ordered amount, product type etc.
| time | field_integer_bestellmenge_value_int | field_float_verlademenge_value_float | tag_generic_name | tag_workorder | tag_rezeptnummer_version | tag_artikelnummer |
| 23.2.21 8:30:00 | 6000 | 5900 | Auftragsdaten | A001 | 17342642_2 | Art001 |
| 23.2.21 9:30:00 | 6000 | 6100 | Auftragsdaten | A002 | 2223600758_1 | Art002 |
| 24.2.21 5:00:09 | 18000 | 18030 | Auftragsdaten | A003 | 17342642_2 | Art003 |
| 25.2.21 7:10:09 | 12000 | 10890 | Auftragsdaten | A004 | 2223600758_1 | Art004 |
I tried to join both tables by the “workorder” column but the result is always “no data”
The Query i tried is
tab1 = from(bucket: “zone/autogen”)
|> range(start: -1000h)
|> filter(fn: (r) =>
r._measurement == “Flux_test”
|> pivot(
rowKey:[“_time”],
columnKey: [“generic_name”,“_field”],
valueColumn: “_value”
tab2 = from(bucket: “zone/autogen”)
|> range(start: -720h)
|> filter(fn: (r) =>
r._measurement == “Schokinag_Testfabrik_Auftragsdaten”
|> pivot(
rowKey:[“_time”],
|> drop(columns:[“_time”])
join(
tables:{A:tab1,B:tab2},
on:[“workorder”],
What i expected is a new table that looks like the following table
Can anyone please help me with this?
I’m using InfluxDB 2.0 and trying to visualize the tables in Grafana 7.4
