Issues loading Grafana template Not working
Hi ,
I was referring this amazing document to implement monitoring for neo4j casual cluster
https://graphaware.com/neo4j/2019/06/14/monitoring-neo4j-prometheus-part-2.html
I was able to create a sample dashboard with few panels. Later found the template(https://grafana.com/grafana/dashboards/10371) which had most of the metrics covered
however the data does’t load as expected with the template.
Im suspecting to do with the variables however i’m not able to fix !!
Kindly help …Thanks in advance !!
