Issues encountered using the loki 6.5.2 chart for SingleBinary using Azure Storage
Issues encountered using the loki 6.5.2 chart for SingleBinary using Azure Storage.
buntu@NARU-Pr5530:~/loki$ helm upgrade --install loki loki/loki --namespace “loki” --reset-values --values “test_new.yaml” -n loki
Release “loki” does not exist. Installing it now.
Error: template: loki/templates/single-binary/statefulset.yaml:44:28: executing “loki/templates/single-binary/statefulset.yaml” at <include (print .Template.BasePath “/config.yaml”) .>: error calling include: template: loki/templates/config.yaml:19:7: executing “loki/templates/config.yaml” at <include “loki.calculatedConfig” .>: error calling include: template: loki/templates/_helpers.tpl:537:24: executing “loki.calculatedConfig” at <tpl .Values.loki.config .>: error calling tpl: error during tpl function execution for “{{- if .Values.enterprise.enabled}}\n{{- tpl .Values.enterprise.config . }}\n{{- else }}\nauth_enabled: {{ .Values.loki.auth_enabled }}\n{{- end }}\n\n{{- with .Values.loki.server }}\nserver:\n {{- toYaml . | nindent 2}}\n{{- end}}\n\npattern_ingester:\n enabled: {{ .Values.loki.pattern_ingester.enabled }}\n\nmemberlist:\n{{- if .Values.loki.memberlistConfig }}\n {{- toYaml .Values.loki.memberlistConfig | nindent 2 }}\n{{- else }}\n{{- if .Values.loki.extraMemberlistConfig}}\n{{- toYaml .Values.loki.extraMemberlistConfig | nindent 2}}\n{{- end }}\n join_members:\n - {{ include "loki.memberlist" . }}\n {{- with .Values.migrate.fromDistributed }}\n {{- if .enabled }}\n - {{ .memberlistService }}\n {{- end }}\n {{- end }}\n{{- end }}\n\n{{- with .Values.loki.ingester }}\ningester:\n {{- tpl (. | toYaml) $ | nindent 4 }}\n{{- end }}\n\n{{- if .Values.loki.commonConfig}}\ncommon:\n{{- toYaml .Values.loki.commonConfig | nindent 2}}\n storage:\n {{- include "loki.commonStorageConfig" . | nindent 4}}\n{{- end}}\n\n{{- with .Values.loki.limits_config }}\nlimits_config:\n {{- tpl (. | toYaml) $ | nindent 4 }}\n{{- end }}\n\nruntime_config:\n file: /etc/loki/runtime-config/runtime-config.yaml\n\n{{- with .Values.chunksCache }}\n{{- if .enabled }}\nchunk_store_config:\n chunk_cache_config:\n default_validity: {{ .defaultValidity }}\n background:\n writeback_goroutines: {{ .writebackParallelism }}\n writeback_buffer: {{ .writebackBuffer }}\n writeback_size_limit: {{ .writebackSizeLimit }}\n memcached:\n batch_size: {{ .batchSize }}\n parallelism: {{ .parallelism }}\n memcached_client:\n addresses: dnssrvnoa+_memcached-client._tcp.{{ template "loki.fullname" $ }}-chunks-cache.{{ $.Release.Namespace }}.svc\n consistent_hash: true\n timeout: {{ .timeout }}\n max_idle_conns: 72\n{{- end }}\n{{- end }}\n\n{{- if .Values.loki.schemaConfig }}\nschema_config:\n{{- toYaml .Values.loki.schemaConfig | nindent 2}}\n{{- end }}\n\n{{- if .Values.loki.useTestSchema }}\nschema_config:\n{{- toYaml .Values.loki.testSchemaConfig | nindent 2}}\n{{- end }}\n\n{{ include "loki.rulerConfig" . }}\n\n{{- if or .Values.tableManager.retention_deletes_enabled .Values.tableManager.retention_period }}\ntable_manager:\n retention_deletes_enabled: {{ .Values.tableManager.retention_deletes_enabled }}\n retention_period: {{ .Values.tableManager.retention_period }}\n{{- end }}\n\nquery_range:\n align_queries_with_step: true\n {{- with .Values.loki.query_range }}\n {{- tpl (. | toYaml) $ | nindent 4 }}\n {{- end }}\n {{- if .Values.resultsCache.enabled }}\n {{- with .Values.resultsCache }}\n cache_results: true\n results_cache:\n cache:\n default_validity: {{ .defaultValidity }}\n background:\n writeback_goroutines: {{ .writebackParallelism }}\n writeback_buffer: {{ .writebackBuffer }}\n writeback_size_limit: {{ .writebackSizeLimit }}\n memcached_client:\n consistent_hash: true\n addresses: dnssrvnoa+_memcached-client._tcp.{{ template "loki.fullname" $ }}-results-cache.{{ $.Release.Namespace }}.svc\n timeout: {{ .timeout }}\n update_interval: 1m\n {{- end }}\n {{- end }}\n\n{{- with .Values.loki.storage_config }}\nstorage_config:\n {{- tpl (. | toYaml) $ | nindent 4 }}\n{{- end }}\n\n{{- with .Values.loki.query_scheduler }}\nquery_scheduler:\n {{- tpl (. | toYaml) $ | nindent 4 }}\n{{- end }}\n\n{{- with .Values.loki.compactor }}\ncompactor:\n {{- tpl (. | toYaml) $ | nindent 4 }}\n{{- end }}\n\n{{- with .Values.loki.analytics }}\nanalytics:\n {{- tpl (. | toYaml) $ | nindent 4 }}\n{{- end }}\n\n{{- with .Values.loki.querier }}\nquerier:\n {{- tpl (. | toYaml) $ | nindent 4 }}\n{{- end }}\n\n{{- with .Values.loki.index_gateway }}\nindex_gateway:\n {{- tpl (. | toYaml) $ | nindent 4 }}\n{{- end }}\n\n{{- with .Values.loki.frontend }}\nfrontend:\n {{- tpl (. | toYaml) $ | nindent 4 }}\n{{- end }}\n\n{{- with .Values.loki.frontend_worker }}\nfrontend_worker:\n {{- tpl (. | toYaml) $ | nindent 4 }}\n{{- end }}\n\n{{- with .Values.loki.distributor }}\ndistributor:\n {{- tpl (. | toYaml) $ | nindent 4 }}\n{{- end }}\n\ntracing:\n enabled: {{ .Values.loki.tracing.enabled }}\n”: template: gotpl:40:6: executing “gotpl” at <include “loki.commonStorageConfig” .>: error calling include: template: loki/templates/_helpers.tpl:287:22: executing “loki.commonStorageConfig” at <$.Values.loki.storage.bucketNames.chunks>: nil pointer evaluating interface {}.chunks
Values.yaml
ubuntu@NARU-Pr5530:~/loki$ cat test_new.yaml
loki/production/helm/loki/values.yaml at main · grafana/loki · GitHub
deploymentMode: SingleBinary
loki:
storage:
type: azure
azure:
accountName: ***
accountKey: ***
useManagedIdentity: false
useFederatedToken: false
query_scheduler:
max_outstanding_requests_per_tenant: 2048
structuredConfig:
query_range:
parallelise_shardable_queries: true
limits_config:
split_queries_by_interval: 0
schemaConfig:
configs:
object_store: azure
store: tsdb
schema: v13
index:
prefix: index_
period: 24h
storage_config:
azure:
account_key: ***
account_name: ***
container_name: loki
use_managed_identity: false
request_timeout: 0
tsdb_shipper:
active_index_directory: /loki/index
cache_location: /loki/index_cache
cache_ttl: 24h
filesystem:
directory: /loki/chunks
singleBinary:
replicas: 1
persistence:
enableStatefulSetAutoDeletePVC: true
affinity:
nodeAffinity:
preferredDuringSchedulingIgnoredDuringExecution:
- preference:
matchExpressions:
- key: kubernetes.azure.com/mode
operator: In
values:
- user
weight: 50
chunksCache:
default is 500MB, with limited memory keep this smaller
allocatedMemory: 1024
writebackSizeLimit: 10MB
resultsCache:
enabled: true
