I keep getting the same linting errors:
╰─ helm lint . -f values-loki.yaml
==> Linting .
[INFO] Chart.yaml: icon is recommended
[ERROR] templates/: template: detect/charts/loki/templates/write/statefulset-write.yaml:50:28: executing "detect/charts/loki/templates/write/statefulset-write.yaml" at <include (print .Template.BasePath "/config.yaml") .>: error calling include: template: detect/charts/loki/templates/config.yaml:19:7: executing "detect/charts/loki/templates/config.yaml" at <include "loki.calculatedConfig" .>: error calling include: template: detect/charts/loki/templates/_helpers.tpl:537:24: executing "loki.calculatedConfig" at <tpl .Values.loki.config .>: error calling tpl: error during tpl function execution for "{{- if .Values.enterprise.enabled}}\n{{- tpl .Values.enterprise.config . }}\n{{- else }}\nauth_enabled: {{ .Values.loki.auth_enabled }}\n{{- end }}\n\n{{- with .Values.loki.server }}\nserver:\n {{- toYaml . | nindent 2}}\n{{- end}}\n\npattern_ingester:\n enabled: {{ .Values.loki.pattern_ingester.enabled }}\n\nmemberlist:\n{{- if .Values.loki.memberlistConfig }}\n {{- toYaml .Values.loki.memberlistConfig | nindent 2 }}\n{{- else }}\n{{- if .Values.loki.extraMemberlistConfig}}\n{{- toYaml .Values.loki.extraMemberlistConfig | nindent 2}}\n{{- end }}\n join_members:\n - {{ include \"loki.memberlist\" . }}\n {{- with .Values.migrate.fromDistributed }}\n {{- if .enabled }}\n - {{ .memberlistService }}\n {{- end }}\n {{- end }}\n{{- end }}\n\n{{- with .Values.loki.ingester }}\ningester:\n {{- tpl (. | toYaml) $ | nindent 4 }}\n{{- end }}\n\n{{- if .Values.loki.commonConfig}}\ncommon:\n{{- toYaml .Values.loki.commonConfig | nindent 2}}\n storage:\n {{- include \"loki.commonStorageConfig\" . | nindent 4}}\n{{- end}}\n\n{{- with .Values.loki.limits_config }}\nlimits_config:\n {{- tpl (. | toYaml) $ | nindent 4 }}\n{{- end }}\n\nruntime_config:\n file: /etc/loki/runtime-config/runtime-config.yaml\n\n{{- with .Values.chunksCache }}\n{{- if .enabled }}\nchunk_store_config:\n chunk_cache_config:\n default_validity: {{ .defaultValidity }}\n background:\n writeback_goroutines: {{ .writebackParallelism }}\n writeback_buffer: {{ .writebackBuffer }}\n writeback_size_limit: {{ .writebackSizeLimit }}\n memcached:\n batch_size: {{ .batchSize }}\n parallelism: {{ .parallelism }}\n memcached_client:\n addresses: dnssrvnoa+_memcached-client._tcp.{{ template \"loki.fullname\" $ }}-chunks-cache.{{ $.Release.Namespace }}.svc\n consistent_hash: true\n timeout: {{ .timeout }}\n max_idle_conns: 72\n{{- end }}\n{{- end }}\n\n{{- if .Values.loki.schemaConfig }}\nschema_config:\n{{- toYaml .Values.loki.schemaConfig | nindent 2}}\n{{- end }}\n\n{{- if .Values.loki.useTestSchema }}\nschema_config:\n{{- toYaml .Values.loki.testSchemaConfig | nindent 2}}\n{{- end }}\n\n{{ include \"loki.rulerConfig\" . }}\n\n{{- if or .Values.tableManager.retention_deletes_enabled .Values.tableManager.retention_period }}\ntable_manager:\n retention_deletes_enabled: {{ .Values.tableManager.retention_deletes_enabled }}\n retention_period: {{ .Values.tableManager.retention_period }}\n{{- end }}\n\nquery_range:\n align_queries_with_step: true\n {{- with .Values.loki.query_range }}\n {{- tpl (. | toYaml) $ | nindent 4 }}\n {{- end }}\n {{- if .Values.resultsCache.enabled }}\n {{- with .Values.resultsCache }}\n cache_results: true\n results_cache:\n cache:\n default_validity: {{ .defaultValidity }}\n background:\n writeback_goroutines: {{ .writebackParallelism }}\n writeback_buffer: {{ .writebackBuffer }}\n writeback_size_limit: {{ .writebackSizeLimit }}\n memcached_client:\n consistent_hash: true\n addresses: dnssrvnoa+_memcached-client._tcp.{{ template \"loki.fullname\" $ }}-results-cache.{{ $.Release.Namespace }}.svc\n timeout: {{ .timeout }}\n update_interval: 1m\n {{- end }}\n {{- end }}\n\n{{- with .Values.loki.storage_config }}\nstorage_config:\n {{- tpl (. | toYaml) $ | nindent 4 }}\n{{- end }}\n\n{{- with .Values.loki.query_scheduler }}\nquery_scheduler:\n {{- tpl (. | toYaml) $ | nindent 4 }}\n{{- end }}\n\n{{- with .Values.loki.compactor }}\ncompactor:\n {{- tpl (. | toYaml) $ | nindent 4 }}\n{{- end }}\n\n{{- with .Values.loki.analytics }}\nanalytics:\n {{- tpl (. | toYaml) $ | nindent 4 }}\n{{- end }}\n\n{{- with .Values.loki.querier }}\nquerier:\n {{- tpl (. | toYaml) $ | nindent 4 }}\n{{- end }}\n\n{{- with .Values.loki.index_gateway }}\nindex_gateway:\n {{- tpl (. | toYaml) $ | nindent 4 }}\n{{- end }}\n\n{{- with .Values.loki.frontend }}\nfrontend:\n {{- tpl (. | toYaml) $ | nindent 4 }}\n{{- end }}\n\n{{- with .Values.loki.frontend_worker }}\nfrontend_worker:\n {{- tpl (. | toYaml) $ | nindent 4 }}\n{{- end }}\n\n{{- with .Values.loki.distributor }}\ndistributor:\n {{- tpl (. | toYaml) $ | nindent 4 }}\n{{- end }}\n\ntracing:\n enabled: {{ .Values.loki.tracing.enabled }}\n": template: gotpl:40:6: executing "gotpl" at <include "loki.commonStorageConfig" .>: error calling include: template: detect/charts/loki/templates/_helpers.tpl:228:19: executing "loki.commonStorageConfig" at <$.Values.loki.storage.bucketNames.chunks>: nil pointer evaluating interface {}.chunks
Below is my full values yaml file:
deploymentMode: SingleBinary
loki:
enabled: true
isDefault: true
auth_enabled: false
server:
http_listen_port: 3100
commonConfig:
replication_factor: 1
path_prefix: /loki
schemaConfig:
configs:
store: boltdb-shipper
object_store: azure
schema: v11
index:
prefix: loki_index_
period: 24h
storage:
type: azure
bucketNames:
chunks: "loki"
rules: "loki"
admin: "loki"
tsdb: "loki"
azure:
accountName: "datadetect"
accountKeySecret:
name: "YOUR_AZURE_STORAGE_ACCOUNT_KEY_SECRET_NAME" # Replace with the name of your Kubernetes Secret
key: "KEY_NAME_IN_SECRET" # Replace with the key name within the Secret (e.g., azurestorageaccountkey)
containerName: "loki"
useManagedIdentity: false
requestTimeout: 0
filesystem:
chunks_directory: /var/loki/chunks
rules_directory: /var/loki/rules
storage_config:
boltdb_shipper:
shared_store: azure
active_index_directory: /var/loki/boltdb-shipper-active
cache_location: /var/loki/boltdb-shipper-cache
cache_ttl: 24h
compactor:
working_directory: /var/loki/retention
shared_store: azure
retention_enabled: true
compaction_interval: 10m
retention_delete_delay: 2h
retention_delete_worker_count: 150
limits_config:
retention_period: 744h
max_query_length: 721h
max_query_parallelism: 32
max_streams_per_user: 10000
creation_grace_period: 168h
split_queries_by_interval: 24h
allow_structured_metadata: true
volume_enabled: true
discover_log_levels: true
pattern_ingester:
enabled: false
tracing:
enabled: false
singleBinary:
replicas: 1
image:
repository: grafana/loki
tag: 3.4.4
pullPolicy: IfNotPresent
persistence:
enabled: true
storageClass: default
existingClaim: loki-pvc
service:
type: ClusterIP
port: 3100
podLabels:
app.kubernetes.io/name: otel-loki
I can confirm i do have a loki container name on the account name specified.
if anyone can spot
what I am doing wrong here, then that would be great!
Also, if anyone recommend any changes or upgrades I should make, i.e tsdb that would also be great.
