Loki helm-chart won't persist to Azure Blob Containers
Hello community!
I am trying to install a simple scalable Loki instance to my AKS environment. The full picture is to have Alloy collecting logs to send to Loki which is plugged into Grafana.
Following your documentation: Install the simple scalable Helm chart | Grafana Loki documentation
My configuration requires persisting to the Azure Blob Containers however I have so far been unable to succeed.
The helm chart builds Loki v3.2.0
What happened?
Loki deploys and seemingly runs fine- all the pods and running and look healthy- however nothing is being written to my blob containers and there is no error or log message telling me why not. The containers are precreated with access to read/write, however they remain empty.
My Plea
I am struggling to find a configuration to get this working between old versions of Loki, and the now decommed Loki-Stack and Loki-Distributed charts.
I appreciate anyone’s help that can be offered.
Values.yaml
loki:
  auth_enabled: false
  schemaConfig:
    configs:
        store: tsdb
        object_store: azure
        schema: v13
        index:
          prefix: loki_index_
          period: 24h
  ingester:
    chunk_encoding: snappy
  tracing:
    enabled: true
  querier:
    max_concurrent: 4
  storage:
    type: azure
    azure:
      # Name of the Azure Blob Storage account
      accountName: redacted
      # Key associated with the Azure Blob Storage account
      accountKey: redacted
      # Comprehensive connection string for Azure Blob Storage account (Can be used to replace endpoint, accountName, and accountKey)
      connectionString: redacted
      # Flag indicating whether to use Azure Managed Identity for authentication
      useManagedIdentity: false
      # Flag indicating whether to use a federated token for authentication
      useFederatedToken: false
      # Timeout duration for requests made to the Azure Blob Storage account (in seconds)
      requestTimeout: 60
      # Domain suffix of the Azure Blob Storage service endpoint (e.g., core.windows.net)
      endpointSuffix: core.windows.net
    bucketNames:
      chunks: "loki-chunks"
      ruler: "loki-ruler"
      admin: "loki-admin"
deploymentMode: SimpleScalable
memberlist:
    service:
      publishNotReadyAddresses: true
backend:
  replicas: 3
read:
  replicas: 3
write:
  replicas: 3
# Disable minio storage
minio:
  enabled: false
# Zero out replica counts of other deployment modes
singleBinary:
  replicas: 0
ingester:
  replicas: 0
querier:
  replicas: 0
queryFrontend:
  replicas: 0
queryScheduler:
  replicas: 0
distributor:
  replicas: 0
compactor:
  replicas: 0
indexGateway:
  replicas: 0
bloomCompactor:
  replicas: 0
bloomGateway:
  replicas: 0
I am facing the similar issue. Did you get any way to solve this?
The ingester service is responsible for persisting data and shipping it to long-term storage. Give a shot if this might solve your issue
Also I wanted to pass down the Azure credentials as secrets, so that it won’t be exposed.
