When i launch grafana i get a 404 error, first initial login always fails, no dashboards exist at all, i can’t adjust user settings or change my password or create dashboards. Its a fresh install of this stack on a kuberetes k3s multinode cluster version v1.21.7.
Really wanted to try this out in my home lab. Any assistance on what I may have done wrong would be super helpful. I expected the out of the box install to at least function so I’m assuming I did something wrong.
I do have a previous installation of rancher monitoring setup just incase this is conflicting with anything but they are in different namespaces.
are you using the “local” Grafana admin account to log in? I would assume the helm run would show the credentials. I have not used this helm chart… My first suspicion would be that the user you use does not have admin access. I could be wrong.
I would also look at the Grafana pods logs. iirc Grafana logs are pretty good at telling you what is not working as expected.
Hello @b0b . To confirm I am using the local grafana admin account that was created by the helm install using the password received from the secret created by the helm install. Neither the grafana container or the grafana datasources container are producing any logs. I find this odd but would be interested if you have any suggestions.
Instead of Promtail I have used Grafana Agent. I have just applied plain text Kubernetes resource files for that.
I have worked on Kubernetes clusters with strict namespaces and network policies. I have left all that out here. This is just to give an idea of what has worked for me.
Hope that helps or at least gives some ideas of what to try.
I checked my Grafana pod and it is logging as expected.
For comparison, here is the full description of my Grafana pod
$ k describe pods grafana-79c9f9c9b8-7gqgt -n grafana
Namespace: grafana
Priority: 0
Node: my-node
Start Time: Sun, 21 Nov 2021 03:10:44 +0100
Labels: app.kubernetes.io/instance=grafana
app.kubernetes.io/name=grafana
pod-template-hash=79c9f9c9b8
Annotations: checksum/config: 15515d821eb302de3708075b9e0dfd28ffb40729c43b3c383d1e80d004d611a7
checksum/dashboards-json-config: 01ba4719c80b6fe911b091a7c05124b64eeece964e09c058ef8f9805daca546b
checksum/sc-dashboard-provider-config: 01ba4719c80b6fe911b091a7c05124b64eeece964e09c058ef8f9805daca546b
checksum/secret: 40b4f702267aeca530e46415edd07bfe51fe19453567c963f5fdc2e4a843bfd4
kubernetes.io/psp: eks.privileged
Status: Running
IP: 10.0.0.1
IPs:
IP: 10.0.0.1
Controlled By: ReplicaSet/grafana-79c9f9c9b8
Init Containers:
init-chown-data:
Container ID: docker://8f4245e96c05043d80f3d63836709338a0218f22098604e302b921f5b8e7e648
Image: busybox:1.31.1
Image ID: docker-pullable://busybox@sha256:95cf004f559831017cdf4628aaf1bb30133677be8702a8c5f2994629f637a209
Port: <none>
Host Port: <none>
Command:
chown
-R
472:472
/var/lib/grafana
State: Terminated
Reason: Completed
Exit Code: 0
Started: Sun, 21 Nov 2021 03:29:15 +0100
Finished: Sun, 21 Nov 2021 03:29:15 +0100
Ready: True
Restart Count: 0
Environment: <none>
Mounts:
/var/lib/grafana from storage (rw)
/var/run/secrets/kubernetes.io/serviceaccount from grafana-token-dq4cp (ro)
Containers:
grafana:
Container ID: docker://ad93ee998edd08f073016a50ee4688a8c6ed06564182c3215a4c65b11289c945
Image: grafana/grafana:8.1.5
Image ID: docker-pullable://grafana/grafana@sha256:b7dd9cd0e59d107bbf8b62ded1860b888955d902a700e1997b1c9f211bcf8708
Ports: 80/TCP, 3000/TCP
Host Ports: 0/TCP, 0/TCP
State: Running
Started: Sun, 21 Nov 2021 03:29:25 +0100
Ready: True
Restart Count: 0
Liveness: http-get http://:3000/api/health delay=60s timeout=30s period=10s #success=1 #failure=10
Readiness: http-get http://:3000/api/health delay=0s timeout=1s period=10s #success=1 #failure=3
Environment:
GF_SECURITY_ADMIN_USER: <set to the key 'admin-user' in secret 'grafana'> Optional: false
GF_SECURITY_ADMIN_PASSWORD: <set to the key 'admin-password' in secret 'grafana'> Optional: false
GF_PATHS_DATA: /var/lib/grafana/
GF_PATHS_LOGS: /var/log/grafana
GF_PATHS_PLUGINS: /var/lib/grafana/plugins
GF_PATHS_PROVISIONING: /etc/grafana/provisioning
Mounts:
/etc/grafana/grafana.ini from config (rw,path="grafana.ini")
Conditions:
Type Status
Initialized True
Ready True
ContainersReady True
PodScheduled True
Volumes:
config:
Type: ConfigMap (a volume populated by a ConfigMap)
Optional: false
storage:
Type: PersistentVolumeClaim (a reference to a PersistentVolumeClaim in the same namespace)
ClaimName: grafana
ReadOnly: false
grafana-token-dq4cp:
Type: Secret (a volume populated by a Secret)
SecretName: grafana-token-dq4cp
Optional: false
QoS Class: BestEffort
Node-Selectors: <none>
Tolerations: node.kubernetes.io/not-ready:NoExecute for 300s
node.kubernetes.io/unreachable:NoExecute for 300s
Events: <none>
