Is there any plan to support elasticsearch 6.0
I’m using ES6.0,and found some problems in Template variable。Is there any plan to support ES6.0, or make user can optimize queries in Template variables
As far as I know 6.0 should work with Grafana. Please see the following issue and respond to that and/or create a new issue reporting your problems.
Thanks
Marcus
I have respond to that issue
https://github.com/grafana/grafana/issues/8765#issuecomment-347386428
Thanks
I found select the ES version to 5.x may correct, when add ES to datasource
