However in my install of Grafana (5.3.4) there is no 6.0+ option.
I looked around in the code and it seems to be absent (even from the 5.4.0-beta1:
switch version {
case 2, 5, 56:
Any reason why the docs seem to be ahead of the actual code ? I found this to be quite confusing as I was looking for the option everywhere and couldn’t find it.
That’s very good spotted. Thank you we’ll fix that to v5.4.0 stable. However, you should be able to select 6.0+ in the datasource configuration using Grafana v5.4.0-beta1.
Fix of this issue required us to add a 6.0+ version selection.
Elasticsearch 6.0 have been supported since Grafana v4.1 when support for Elasticsearch 5 was added. At least I think. So nothing stopping you trying out Grafana with Elasticsearch before 5.4.0 is released. Besides 5.4.0-beta1 that is
