Grafana v9.1.6 in linux (k8s pod) -
I want to be able to hover over a point in a time series and get a total (sum) of the values:
For example here it would be nice to have a tooltip with a sum of all other values at that point.
I’m not in any way as I don’t know if this is supported or not. -
What happened?
No tooltip is shown -
I want a total value shown -
