Hi there,
I’m collecting trigger based data in Influx and am trying to plot this data sequentially using the plot panel. See image below.
Since this data is collected using triggers, there are occasionally gaps in the data if the trigger condition stops. I would ideally like to ignore these gaps and simply plot the data points sequentially.
So instead of plotting “measurement versus time”, I just want to plot “measurement” in the order they were captured.
Is there a way to achieve this behavior in Grafana?
