Hi Engineers,
I am setting up a new dashboard. I would like to provide a Linux swappiness value in the dashboard. Are there any metrics available for obtaining the swappiness value?
Hi Engineers,
Have you looked at node exporter?
or telegraf to extract this data to a db
As far as I know, there is no swappiness metrics available in the node exporter. Is there a way to get this value? It would be very helpful to create a custom dashboard for memory/swap monitoring.
I would try telegraf using a python script with psutil that pushes data to a csv file or to your fav database such as inflix or mysql on cron
