Hi Team, we are not able to get the RAM usage details on the Grafana dashboard, Datasource we are using is Prometheus, below are the versions:
We are using node_exporter full to collect the data from the host machines
Have you enabled the swap file on your CentOS server? If not, then I believe SWAP Used will return an empty value and default to N/A. That’s what I’m getting on my Ubuntu machines and I’m using the Node Exporter Full dashboard straight out-of-the-box.
Let’s try and test this. Go to the Explore feature in Grafana and select your Prometheus datasource. Now try the following query:
