I’m trying to achieve having a single dashboard that will jointly display data coming from both node_exporter and windows_exporter.
In particular I’m trying to have metrics coming from windows_exporter to be visualized in the same panels with metrics coming from node_exporter.
The dashboard has the following panels:
CPU Usage %
Memory Usage %
System Load Average
System Pressure Stall
Disk Usage %
Disk IOps
Disk Utilization %
Network Traffic
System Information
So far, I’ve been able to fill in the panels where their queried metrics somehow have an equivalent between node_exporter and windows_exporter.
Namely:
CPU Usage %:
| node_exporter | windows_exporter |
node_cpu_seconds_total |
windows_cpu_time_total |
Memory Usage %:
node_memory_MemAvailable_bytes |
windows_memory_available_bytes |
node_memory_MemTotal_bytes |
windows_memory_physical_total_bytes |
Network Traffic:
node_network_receive_bytes_total |
windows_net_bytes_received_total |
node_network_transmit_bytes_total |
windows_net_bytes_sent_total |
System Information:
node_boot_time_seconds |
windows_system_boot_time_timestamp |
What remains is finding out how to proceed with the following sections and their respectful metrics:
System Load:
node_load1 |
node_load5 |
node_load15 |
System Pressure Stall:
node_pressure_io_stalled_seconds_total |
node_pressure_cpu_stalled_seconds_total |
node_pressure_memory_stalled_seconds_total |
Disk Usage %:
node_filesystem_avail_bytes |
node_filesystem_size_bytes |
Disk IOps:
node_disk_reads_completed_total |
node_disk_writes_completed_total |
Disk Utilization %:
node_disk_io_time_seconds_total |
So taking all these into account my question is that as I have the feel that my need is not unique to my setup, meaning others too would benefit from having a dashboard that combines metrics from both node_exporter and windows_exporter how come there isn’t a dashboard template that achieves that?
