as mentioned below, that is because you have clicked on share dashboard (and not share panel), which doesn’t have the direct link rendered image option. To share panel (and get direct link rendered image), choose share option from the panel’s dropdown.
I have the same problem.
I am doing a test using “Remote Rendering”, but I am not able to create the image of the entire dashboard, just a single graphic inside the dashboard.
Within the share menu of the dashboard you do not have the option “Direct link rendered image” to capture the entire dashboard.
What is the right way to capture the entire image of the dashboard?
hi, sorry its a old thread, but i am encountering the same requirement at present. is it possible to render a panel as image using api? I could do like as follows: but wondering is there a way to do with api using panel name
