My Grafana cannot be started in the container, and some information cannot be deleted
logger=context userId=0 orgId=1 uname= t=2023-12-29T09:16:08.09207904+08:00 level=info msg="Request Completed" method=GET path=/api/live/ws status=-1 remote_addr=192.168.10.6 time_ms=5 duration=5.180919ms size=0 referer= handler=/api/live/ws
logger=grafana.update.checker t=2023-12-29T09:16:35.734989393+08:00 level=info msg="Update check succeeded" duration=707.091351ms
logger=cleanup t=2023-12-29T09:26:05.071661009+08:00 level=info msg="Completed cleanup jobs" duration=47.253429ms
logger=plugins.update.checker t=2023-12-29T09:26:06.155656083+08:00 level=info msg="Update check succeeded" duration=556.390708ms
logger=grafana.update.checker t=2023-12-29T09:26:38.234567404+08:00 level=info msg="Update check succeeded" duration=3.207046597s
logger=infra.usagestats t=2023-12-29T09:27:16.050775681+08:00 level=info msg="Usage stats are ready to report"
error from daemon in stream: Error grabbing logs: invalid character 'l' after object key:value pair
Hi @janexiaoer,
Welcome to the
community support forums !!
We are excited that you joined our OSS community. Please read about some of the FAQs in the community ![:slight_smile: :slight_smile:](https://emoji.discourse-cdn.com/twitter/slight_smile.png?v=12)
Please review the submission template and include more details:
- What is your datasource?
- What visualization panel you are using e.g. time-series, bar chart, histogram etc?
- What are you trying to achieve?
- How are you trying to achieve it?
- What happened?
- Can you copy/paste the configuration(s) that you are having problems with?
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
- Did you follow any online instructions? If so, what is the URL?
antonio
3
hi @janexiaoer
It seems that this might be a docker related issue
In the bellow link there are a couple things that you might want to try:
Let us know how it went!
