Lvl=eror msg="failed to load dashboard from " logger=provisioning.dashboard type=file name=default file=/var/lib/grafana/dashboards/default/Deployments-Dashboard.json error="invalid character '<' looking for beginning of value"
I get this error after configuring dashboard provider.
my dashboards are hosted on github pages.
lvl=eror msg="failed to load dashboard from " logger=provisioning.dashboard type=file name=default file=/var/lib/grafana/dashboards/default/Nodes-Dashboard.json error=“invalid character ‘<’ looking for beginning of value”
lvl=eror msg="failed to load dashboard from " logger=provisioning.dashboard type=file name=default file=/var/lib/grafana/dashboards/default/System-dashboard.json error=“invalid character ‘<’ looking for beginning of value”
lvl=eror msg="failed to load dashboard from " logger=provisioning.dashboard type=file name=default file=/var/lib/grafana/dashboards/default/Deployments-Dashboard.json error=“invalid character ‘<’ looking for beginning of value”
Is anyone familiar with this error? if so can you share with me your experience on how you got it fixed?
When I load these dashboards manually into grafana, they work fine.
Hi did you solve this issue? I got the same problem
I had same issue in Kubernetes environment
with logging in to the pod, just removed dashboard file in the /var/lib/grafana/dashboards/ and then redeployed dashboard
How to solve the problem?
