Hi all,
i want to create a simple time series dashboard chart from a TimescaleDB database. For that, i use the $__interval variable:
SELECT
$__timeGroupAlias(ref_timestamp, $__interval),
AVG(value)
FROM database
WHERE $__timeFilter(ref_timestamp) AND tag = 'EXAMPLE'
GROUP BY time
In the query inspector, i see:
SELECT
time_bucket('60.000s',ref_timestamp) AS "time",
AVG(value)
FROM database
WHERE ref_timestamp BETWEEN '2026-02-08T10:22:15.122Z' AND '2026-02-09T10:22:15.122Z' AND tag = 'EXAMPLE'
GROUP BY time
Regardless of the time period (30 minutes, 1 hour, 1 day…), the $__interval is always translated to ‘60.000s’.
What i am do wrong ?
Thanks !
PS: i use Grafana v12.3.1
What are your query options?:
Or just create custom interval variable, where you can customize ‘auto’ option for your needs + still have option to select period explicitly, e.g.:
Hi @jangaraj
Thanks for your help.
My query option are the default one:
I try to change the Min interval field to 5s but it does not change Interval (alway computed to 1m).
In the meanwhile i also configure a custom interval variable but only value > 1m are available in the menu:
Is there any global configuration variable at Grafana level that can limit the minimum sampling period ?
Did you configure that on the datasource level?
Nope, did not set anything:
Changing the default setting to 5s (my use case):
Do not change anything:
- custom interval variable only display value >= 1m
- interval variable never return value <1m
After some test (recreating data source / dashboard), the last solution works.
Request are now done with a sampling of 5 seconds when needed.
Thanks @jangaraj !
