I am fairly new to Grafana therefore, I am sure there is a simple solution to my problem. I successfully created a multi-variable dashboard but few panels showed “No data”. The issue is that the query for those panels is slightly different than the base query (e.g., port1 vs x1) because the targets are using different labels. I edited the non-working panels to adjust the queries but the changes propagate to ALL panels and the working panels stop showing data. I was expecting to have a base template and customize certain query/panels. Is this the expected behavior of interactive dashboards or I am doing something wrong? Many thanks.
Hi @merv500,
Welcome to the Grafana Community!
Take a look at this thread and see if it helps you out. Report back with more info and screenshots if you need more help
