I was just given a dashboard that apparently had been working correctly and has now changed. There are a dozen graphs, and 2 are working correctly. The graphs working as intended are displaying lines, and when you mouse across them they display data across the entire line and shows the transitions of data.
Now I edit another graph, the settings look identical, however its only displays dots. Now mouse over a dot and it shows info, but you only can display info for the specific timestamp of that dot, no line where I can follow the change.
I turned on Staircase on one and it “looks” better, as it has lines, but does not show data between the dots.
Issue is seen across windows 10, windows8 and MACOS
What are you trying to achieve? Make all graphs in the dashboard the same again
How are you trying to achieve it? Dont really care, if it works.
What happened? Not sure, was asked to look into the error
What did you expect to happen? Someone to show me what I am missing
Can you copy/paste the configuration(s) that you are having problems with? Not sure what part of the config controls this, since the items that work and dont work seem to be setup the same, i can post stuff, but might need to have a specific request.
Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were. Nope
Did you follow any online instructions? If so, what is the URL? Nope, didnt find anything that seemed to apply.
