Hello everyone,
I am using Grafana v7.4.1 (07649d1313) and I am using the Azure Connector to access both metrics and Logs, I have used a service principal with system wide read permissions as described here.
I can query metrics and wirte KSL just fine. but my problem comes when defining variables.
Lets say I need to have a list of all the available resource groups.
I usually do something like this.
AzureMetrics
| distinct ResourceGroup
But this query does not work on the variable pane. In fact I can only see AzureAnalytics and Usage there:
Is is something I am doing wrong ? Maybe the scope needs to specified ?
Again, if I build a panel on the dashboard this does not happen.
Since no one replied here. I will reply the solution I have worked out in order to have variables with azure metrics.
I enabled the sqlite plugin.
Using this script:
#!/usr/bin/python
from azure.identity import ClientSecretCredential
from azure.mgmt.resource import ResourceManagementClient
from datetime import datetime
import os
import sqlite3
import time
""" Gets Azure resource groups and virtaul machines
I assume the following variables exist
AZURE_TENANT_ID: with your Azure Active Directory tenant id or domain
AZURE_CLIENT_ID: with your Azure Active Directory Application Client ID
AZURE_CLIENT_SECRET: with your Azure Active Directory Application Secret
AZURE_SUBSCRIPTION_ID: with your Azure Subscription Id
Optionally:
DATA_DB_PATH: The path for the sqlite database to be in otherwise, if not
set it be data.db on the current directory
db_path = "data.db"
if os.environ.get("DATA_DB_PATH"):
db_path = os.environ.get("DATA_DB_PATH")
if not os.path.exists(os.path.dirname(db_path)):
print("Creating database basedir: {dir}".format(dir = os.path.dirname(db_path)))
os.mkdir(os.path.dirname(db_path))
conn = sqlite3.connect(db_path)
conn.execute("""
CREATE TABLE IF NOT EXISTS virtual_machines
(id INTEGER PRIMARY KEY AUTOINCREMENT, resource_group VARCHAR(50), name TEXT);""")
conn.execute("""CREATE UNIQUE INDEX IF NOT EXISTS idx_virtual_machines_name
ON virtual_machines (name);""")
def fetch_data():
subscription_id = os.environ.get("AZURE_SUBSCRIPTION_ID")
client_id = os.environ.get("AZURE_CLIENT_ID")
client_secret = os.environ.get("AZURE_CLIENT_SECRET")
tenant_id = os.environ.get("AZURE_TENANT_ID")
credentials = ClientSecretCredential(
client_id = client_id,
client_secret = client_secret,
tenant_id = tenant_id
client = ResourceManagementClient(credentials, subscription_id)
for res_group in client.resource_groups.list():
print("Listing resources for {n}".format(n = res_group.name))
for res in client.resources.list_by_resource_group(res_group.name):
if res.type == "Microsoft.Compute/virtualMachines":
conn.execute("INSERT OR REPLACE INTO virtual_machines(resource_group, name) VALUES(?,?)", [res_group.name, res.name])
conn.commit()
interrupt = False
while not interrupt:
try:
fetch_data()
if not interrupt:
print("Resting for 10 minutes")
time.sleep(600)
except(KeyboardInterrupt, SystemExit):
print("Received Keyboard Interrupt or system existing, exiting")
interrupt=True
conn.close()
And then you can query the information from the database.
Here is a full example: Collect Azure Resource List and Virtual Machines into SQLite · GitHub
I hope this is useful for anyone. Since it makes no sense the lack of ability to not query information from withing the variables on some cases.
