Hi All,
I just started using Grafana and are really enjoying the product.
I currently use it to Monitor our Azure Environment with Azure monitor plugin. This works like it should. However I’m struggling to template this.
I’m trying to fill my Variables by chaining them this seems to break after the second level.
Sub → ResourceGroup → ResourceType → ResourceName.
I can find the related resource groups of the Sub when I filter it. Any deeper however doesn’t show any result. I tried multiple ways and followed the examples specified on the website:
And yes the resource group has Virtual Machines :).
Any help would be appreciated!
