I have a problem that when I install the zabbix plug-ins it doesn’t show the zabbix data source inside grafana, I’m using the latest version of garfa version 10.
could zanyone help me
Try going in
Home > Connections > Data Sources
Data sources “Add new data source” then search for zabbix
I’m going exactly this way, but the zabbix database doesn’t seem to work. The plugin has already been installed in grafana
Does it show and doesn’t work
Or it doesn’t show at all?
