I’ve installed some plugins through windows command prompt using grafana-cli successfully. The problem is I’m not able to view/use installed plugins on grafana. I’ve used the following commands to install a plugin for your reference:
C:\WINDOWS\system32>cd C:\Program Files\GrafanaLabs\grafana\bin
C:\Program Files\GrafanaLabs\grafana\bin>grafana-cli.exe plugins install jdbranham-diagram-panel
After suucessfully installed:
C:\Program Files\GrafanaLabs\grafana\bin>grafana-server restart
Grafana Version: 6.7.1 (Open Source)
Please help.
