Enterprise (Free & unlicensed)v8.1.2 (103f8fa094)
Windows 10 Enterprise 20H2 -
Install/Use the OPCUA DataSource Plugin -
Data Source Instructions.
Unzipped the file to \GrafanaLabs\grafana\data\plugins.
Used yarn install and yarn build, dont know where to use make build. Tried make build:
C:\Program Files\GrafanaLabs\grafana\data\plugins\opcua-datasource-main\backend>make build
‘make’ is not recognized as an internal or external command,
operable program or batch file.
Also tried it in \opcua-datasource-main
What happened?
I can add the Plugin in Grafana and configure my datasource, but it’s unavailable when I try to save and test it.
Plugin Unavailable -
See OPCUA Datasource
