Hi.
We have a server currently running with Icinga2 and wanted to add some data visualisation to it.
I can install Grafana using the guides and it’s installed fine and I could connect to port 3000 but because this server is in a DMZ I would need to request the ports to be open.
Icinga is running under server.name/icingaweb2/
How can I use grafana to work under server.name/grafana?
Thanks a lot
