Ubuntu Server 24.04 LTS -
Server monitoring -
I go to Connections, choose Linux Server,
- Select platform → Debian - AMD64
- Install Grafana Alloy → Run Grafana Alloy
Choose a name and create API token.
Copy the long command to clipboard and run it on my server.
The command output:
--- Using package system deb. Downloading and installing package for amd64
############################################################################################################################################################################# 100.0%
--- Verifying package checksum
Selecting previously unselected package alloy.
(Reading database ... 173781 files and directories currently installed.)
Preparing to unpack /tmp/alloy-1.7.4-1.amd64.deb ...
Unpacking alloy (1.7.4-1) ...
Setting up alloy (1.7.4-1) ...
--- Retrieving config and placing in /etc/alloy/config.alloy
--- Verifying config checksum
--- Creating systemd override file for environment variables
--- Enabling and starting alloy.service
Created symlink /etc/systemd/system/multi-user.target.wants/alloy.service → /usr/lib/systemd/system/alloy.service.
Alloy is now running!
To check the status of Alloy, run:
sudo systemctl status alloy.service
To restart Alloy, run:
sudo systemctl restart alloy.service
The config file is located at:
systemctl status alloy shows Active (running), no errors
I see alloy in processes (top)
What happened?
I press Test Alloy connection and it fails:
Oops! Something went wrong. Make sure the install instructions were copied correctly and check for any optional configurations. If you’re still running into issues, read the troubleshooting instructions. -
Successful connection -
no errors -
Linux Server integration | Grafana Cloud documentation
