Hi everyone,
I have created a panel with a CSV data source and set some filtering values.
When I inspect it, the system exports the entire CSV data, which is not what I want.
Is there a setting where I can ensure that when inspecting, it exports only the data filtered on the panel?
I do not wish to rely on the ‘Apply Panel Transformation’ filter in the inspection, as not all users will necessarily choose this filter.
Is there a way to configure it so that when inspecting, it directly exports the data that I have filtered on the panel?
Perhaps using the Infinity datasource for your CSV will give you more settings that ensure you are looking at only the desired filtered data. More here.
I try to use Infinity Datasource, but I am not sure how to use it.
My Data have an office column, like HQ, AC, etc.
I only want to show HQ, but if I use a transform.
The result will be the same as what I originally did.
What can I do?
I also tried using UQL, but I still encountered the problem that I couldn’t filter out the value I needed and let it be displayed.
