8.1.1 -
Query InfluxDB -
I am able to query direct, however Grafana is logging a proxy 407 error -
What happened?
This data source is an influxDB installed on the same VM as Grafana. Grafna a logs ‘failed to fetch’ on queries to the DB, and the logs contains e.g.
t=2022-06-24T00:03:45+0100 lvl=eror msg=“Alert Rule Result Error” logger=alerting.evalContext ruleId=4 name=“DCB Vodafone Internet alert” error=“request handler error: failed to query data: InfluxDB returned error status: 407 Proxy Authorization Required” changing state to=alerting -
If i run a select statement against the DB using local CMD, I am able to get output. I expect Grafana to also get this output. -
Not sure of the config. I have looked at the proxy setting on the server, and also checked the proxy logs (Which don’t contain anything for this server IP) -
Failed to fetch -
Lots of googling but no luck - any help really appreciated!
how are you running the grafana and influx services? Are they binaries on disk, installed by package-managers? Are they running in containers? Just trying to think of reasons that one can’t communicate with the other while both are running on the same server
