Hi Guys,
Need help on below:-
I am using below TIG stack versions
Grafana v6.0.0
InfluxDB v1.7.4
We have InfluxDB and Grafana installed on same server.
All permissions for owner of grafana and influxdb important directories are correct.
Also Influxdb service status looks good as data is dumping records into Influx database
Getting error below when I check grafana-server status:-
2019/12/18 16:33:55 http: proxy error: dial tcp ip-address:8086: connect: connection refused
Below error occurs only when some dashboard panels go blank and gives out error as Network Error: undefined(undefined) and after some time whole dashboard goes blank giving out error as Network error:Bad Gateway(502)
Also I checked logs from grafana.log got a couple of issues one of them is above and second is given below:-
t=2019-12-10T15:25:45+0530 lvl=eror msg=“Request error” logger=context userId=1 orgId=1 uname=admin error=“net/http: abort Handler” stack=“/usr/local/go/src/runtime/panic.go:513 (0x435098)\n/usr/local/go/src/net/http/httputil/reverseproxy.go:284 (0xabb577)\n/go/src/github.com/grafana/grafana/pkg/api/pluginproxy/ds_proxy.go:99 (0xd0f66c)\n/go/src/github.com/grafana/grafana/pkg/api/dataproxy.go:35 (0xfed2b2)\n/go/src/github.com/grafana/grafana/pkg/api/api.go:258 (0x1020d03)\n/usr/local/go/src/runtime/asm_amd64.s:522 (0x46385a)\n/usr/local/go/src/reflect/value.go:447 (0x4c1223)\n/usr/local/go/src/reflect/value.go:308 (0x4c0cb3)\n/go/src/github.com/grafana/grafana/vendor/github.com/go-macaron/inject/inject.go:177 (0x7966d3)\n/go/src/github.com/grafana/grafana/vendor/github.com/go-macaron/inject/inject.go:137 (0x796039)\n/go/src/github.com/grafana/grafana/vendor/gopkg.in/macaron.v1/context.go:121 (0x7b2330)\n/go/src/github.com/grafana/grafana/vendor/gopkg.in/macaron.v1/context.go:112 (0x7b224e)\n/go/src/github.com/grafana/grafana/pkg/middleware/request_tracing.go:25 (0xa4f16c)\n/usr/local/go/src/runtime/asm_amd64.s:522 (0x46385a)\n/usr/local/go/src/reflect/value.go:447 (0x4c1223)\n/usr/local/go/src/reflect/value.go:308 (0x4c0cb3)\n/go/src/github.com/grafana/grafana/vendor/github.com/go-macaron/inject/inject.go:177 (0x7966d3)\n/go/src/github.com/grafana/grafana/vendor/github.com/go-macaron/inject/inject.go:137 (0x796039)\n/go/src/github.com/grafana/grafana/vendor/gopkg.in/macaron.v1/context.go:121 (0x7b2330)\n/go/src/github.com/grafana/grafana/vendor/gopkg.in/macaron.v1/context.go:112 (0x7b224e)\n/go/src/github.com/grafana/grafana/pkg/middleware/request_metrics.go:17 (0xa4ea87)\n/usr/local/go/src/runtime/asm_amd64.s:522 (0x46385a)\n/usr/local/go/src/reflect/value.go:447 (0x4c1223)\n/usr/local/go/src/reflect/value.go:308 (0x4c0cb3)\n/go/src/github.com/grafana/grafana/vendor/github.com/go-macaron/inject/inject.go:177 (0x7966d3)\n/go/src/github.com/grafana/grafana/vendor/github.com/go-macaron/inject/inject.go:137 (0x796039)\n/go/src/github.com/grafana/grafana/vendor/gopkg.in/macaron.v1/context.go:121 (0x7b2330)\n/go/src/github.com/grafana/grafana/vendor/gopkg.in/macaron.v1/context.go:112 (0x7b224e)\n/go/src/github.com/grafana/grafana/pkg/middleware/recovery.go:147 (0xa4e9a0)\n/go/src/github.com/grafana/grafana/vendor/gopkg.in/macaron.v1/context.go:79 (0x7b21d0)\n/go/src/github.com/grafana/grafana/vendor/github.com/go-macaron/inject/inject.go:157 (0x7963c0)\n/go/src/github.com/grafana/grafana/vendor/github.com/go-macaron/inject/inject.go:135 (0x79612b)\n/go/src/github.com/grafana/grafana/vendor/gopkg.in/macaron.v1/context.go:121 (0x7b2330)\n/go/src/github.com/grafana/grafana/vendor/gopkg.in/macaron.v1/context.go:112 (0x7b224e)\n/go/src/github.com/grafana/grafana/pkg/middleware/logger.go:34 (0xa4c1ed)\n/usr/local/go/src/runtime/asm_amd64.s:522 (0x46385a)\n/usr/local/go/src/reflect/value.go:447 (0x4c1223)\n/usr/local/go/src/reflect/value.go:308 (0x4c0cb3)\n/go/src/github.com/grafana/grafana/vendor/github.com/go-macaron/inject/inject.go:177 (0x7966d3)\n/go/src/github.com/grafana/grafana/vendor/github.com/go-macaron/inject/inject.go:137 (0x796039)\n/go/src/github.com/grafana/grafana/vendor/gopkg.in/macaron.v1/context.go:121 (0x7b2330)\n/go/src/github.com/grafana/grafana/vendor/gopkg.in/macaron.v1/router.go:187 (0x7c2b27)\n/go/src/github.com/grafana/grafana/vendor/gopkg.in/macaron.v1/router.go:303 (0x7bd29e)\n/go/src/github.com/grafana/grafana/vendor/gopkg.in/macaron.v1/macaron.go:220 (0x7b67f1)\n/usr/local/go/src/net/http/server.go:2741 (0x6b379a)\n/usr/local/go/src/net/http/server.go:1847 (0x6afb35)\n/usr/local/go/src/runtime/asm_amd64.s:1333 (0x465570)\n”
After this influxdb again reads all shards/files shows data points on dashboard and whole story gets repeated but data loading into InfluxDB seems good. I think issue arises from grafana itself but unable to pin point.
Please let me know if you all need more information.
Warm Regards,
//Ashlesh Mandke
