- v10.1.5
- Parse JSON data using the backend parser JSONata that splits and selects the last part off the string value
- Example Data
{ "run": { "configuration": { "testcase": "ctest.development" }, "started": "2025-09-10T21:39:17.004459Z" } }
{"run":run.started,"test":$split(run.configuration.testcase,'.')[-1]}
What happened?
- No data appears..
- A json result like
{"run": 2025-09-10T21:39:17.004459Z, "test": "development"}
- I get the proper result when I plug both of the above in here
- None
Can’t believe it was that simple! Just brackets
Thank you. ![]()
