Hi Everyone
I pretty new to Grafana, and I’m working on a refactory to create a new dashboard based on the API from a previous one based on a CSV file, the previous one have a SQL query to parse the data and show in a bar chart panel, group by date, and in each day show the count of each group found, here below for clarity
SELECT SUBSTRING("time",1 ,10) AS "date"
COUNT(CASE WHEN
"element name" NOT LIKE 'OS%' AND
"Parameter description" NOT LIKE '%ATVA%' AND
"Parameter description" NOT LIKE '%TSPT%'
THEN 1 END) AS "Other",
COUNT(CASE WHEN "element name" LIKE 'OS%' THEN 1 END) AS "nCC",
COUNT(CASE WHEN "Parameter description" LIKE '%ATVA%' THEN 1 END) AS "ATV",
COUNT(CASE WHEN "Parameter description" LIKE '%TSPT%' THEN 1 END) AS "Sentry"
FROM "prod_shasrv_euw2_insight_grafana_general_db"."tb_platform_control_csv_data"
WHERE
$__timeFilter(date_parse(SUBSTRING("time", 1, 10), '%Y/%m/%d'))
AND "element name" NOT LIKE '%MCM9000-SN%'
GROUP BY
1
ORDER BY
"date"
Now I spend the last 2 days to try to replicate the same query on the the Jsonata parser but without any luck, can I ask for an help to do this conversion? this is the kind of data I’m recive via API
"d": [
"DataMinerID": 11111,
"HostingAgentID": 22222,
"ID": 357587,
"RootAlarmID": 338575,
"ElementID": 85,
"ElementName": "Zixi Zen Master Test",
"IsElementMasked": false,
"ParameterID": 7002,
"ParameterName": "Type (Events) xwxkq6o5mn",
"TableIndex": "xwxkq6o5mn",
"DisplayValue": "error",
"AlarmState": "Critical",
"Type": "Escalated From Warning",
"IsAggregation": false,
"IsMasked": false,
"Services": [],
"TimeOfArrival": "2026-03-19 08:40:56",
"TimeOfArrivalUTC": 1773909656000,
"RootTime": "2026-03-17 19:02:01",
"RootTimeUTC": 1773774121000,
"IsTrending": false,
"IsOwner": false,
"OwnerName": "System",
"LastChangeUTC": 1773909679578,
"IsCleared": false
