Hello there,
I am using Grafana grafana/grafana:9.1.5 on a dockerized system (Ubuntu).
EDIT:
waiting till the dashboard loading times out gives me these errors:
I am trying to open up a freshly created dashboard that worked fine, only when it was open. What I mean by this is that when I closed the dashboard and opened it up again it is stuck in loading.
I believe this is a problem with the Variables I am using that come from an Infinity Datasource:
since I see in the container log a huge amount of these:
logger=plugin.yesoreyeram-infinity-datasource t=2022-09-15T10:46:17.168330601Z level=error msg="error getting response for query" error="500 Internal Server Error"
The variables and settings that I am using are working fine:
and inside the query is working fine with no errors.
What happens is that when I close the dashboard it will take at least 50 page refreshes to get a chance of it loading correctly.
(the query inside the yellow panel uses two variables that are dependend on another data source, that works fine)
Maybe is it a race condition problem?
