Hello everyone,
I would like to separate my request from Infinity table
I want line one to be independent of line two so that I can display them in different gauges
Thanks for your helpfull
Hello everyone,
Since I don’t know the datasource (you may be able to filter with a parameter value depending on the API) an easy solution would be to duplicate the panel and then add a filter transformation on each. The filter could be defined to limit for the VPN record on one panel and Internet on the other.
