hi, there
I am currently using the Grafana V8.0 and influxDB as the data source.
I add a graph and try to add an alert rule for this graph.
the data in database is received from a IOT device every 5 second, just like this:
here is the alert rule I added for the graph:
from my understanding, the rule means:
the rule will run every 1 minute, to get the data from now-1m to now, so theoretically, the query result should contain 12 points each time, because one minute should contain 12 points as shown in the first picture, but unluckily, after I click the test rule button, each time the number of the query result is different, sometimes it contains 2 points, sometimes it contains 6 points, as shown in the 2nd floor:
I am not sure it is due to the network quality or the configuration is wrong, or my understanding is not correct? could anyone give me a hand for this issue?
thanks in advance
