In alerts notification, the link directs to the panel but without timestamp
When an alert is triggered, the notification includes the alert information, an image of the graph, and a link to the panel.
But the link is a generic one without the relevant time stamp, so if you click it after a period of time, it loses the connection to the outage.
As the Grafana supports timestamp param in URLs, is it possible the alerts link to the panel will include the relevant time stamp?
For example, an hour before till an hour after the event.
Thanks.
Grafana’s transition from legacy alerting to the Unified Alerting platform represents a big step forward. But, there are many factors that can influence behavior, and it is often hard for the community to troubleshoot issues without a thorough understanding of your unique setup. Try to include the following info:
  • What is your Grafana version?
  • Are you using Grafana Cloud or self-hosted Grafana?
  • Are you using legacy alerting or Unified Alerting?
  • was the alert in question migrated from the legacy platform into Unified Alerting, or did you first create it inside the new platform?
  • Please list ALL configuration options related to alerting. You can find these in the Alerting and Unified Alerting sections of Grafana’s config file. If you are now using or have previously used the beta version of ngalert (released with Grafana 8), please note that too.
    • you can use this table to better understand how configuration options can interact with each other
  • If this is a templating issue on Unified Alerting, check if your alert is using a multi-dimensional rule or not.
  • List the datasource associated with the alert
  • Increase the verbosity of the Grafana server logs to debug and note any errors. For printing to console, set the console logs to debug as well.
  • Search for open issues on GitHub that sound similar to your problem
