I.m using Ubuntu 22.04 and Grafan v9.1.1 -
I’m upgrading the Grafana Image Renderer from v3.3.0 (which worked beautifully) to v3.6.1 due to CVE-2022-31176 -
I’m installing using grafana-cli plugins install grafana-image-renderer -
What happened?
- The install succeeded, it asked me to restart grafana-server (done)
- grafana-cli plugins ls show correct version 3.6.1
- Open grafana in browser, check plugins > grafana-image-renderer > version shows correct version 3.6.1
- Testing the rendering (open dashboard > panel > share > direct link) failed
It should open new tab with rendered image of the panel -
- I use the plugins in plugin mode
grafana.ini : - I added token in [rendering] section
- I added (same) token in [grafana-image-renderer] section
logger=context traceID=00000000000000000000000000000000 userId=0 orgId=1 uname= t=2022-09-08T11:29:27.831852305+07:00 level=error msg=“Rendering failed.” error=“rpc error: code = Unauthenticated desc = Unauthorized request” -
Security release: New versions of Grafana and Grafana Image Renderer with a high severity security fix for CVE-2022-31176 | Grafana Labs
